If you are using BT there is no need to update the regular controllers if you are not using them.
Not seeing the RG Plugin 2 being specifically called out on the web site as a new version. Is it available to order and I am simply missing it somehow?
I updated my firmware to the latest, and now the warm up self test never passes. Any idea why this would happen? It behaves like I am near a wall when I start it up. It just goes red and beeps continuously.
Probably because the new self check is more detailed to catch issues and not let you drive off thinking you are protected if it finds an issue. If its beeping a continuous 2 beeps and does not stop its either because all your sensors on one side of the vehicle are blocked or you have a sensor failure. You need to disconnect one sensor at a time until the alert stops and you will be able to troubleshoot which sensor is tripping the error.
Next Update due out on 5/6 will have a fix for this and add a few more things.
Tom, I have not yet downloaded the 3/24/15 firmware upgrades to my ALP system due to the problems some people experienced. When the 5/6/15 Update becomes available, can I just download it to my ALP system, or should I first download the 3/24/15 Upgrade, then download the 5/6/15 Upgrade?
Thanks.
I see the 5.1.2 update is out. Changes?
Will do! Thanks for keeping us updated.
Very glad to know!
Oops, then. I updated, system says the correct firmware is installed (5.1.2), but keeps asking me to update the voice pack which I thought I did.
I dont understand why everyone can not wait until we post that an update is ready? The required additional files will not be available for a good 12 more hours or so. DO NOT UPDATE until you receive the email that the update is ready or we post that it is good to download.
I sent you the required matching voice pack needed for this update. For everyone else first thing in the morning you will be able to download and install this update. I will post notes in the morning but this is an important update and especially more important for anyone that is in an area where Dragon Eye guns are used. Please do not skip over this update.
Thanks, Tom! Installing right now!
Got nosey and checked the update page out. "Zero to sixty" mode? Shut up and take my money!!!
LOL.. Yeah.. Certainly not what's important about the update but I guess one of the engineers squeezed this feature in with the update. In order to use this 0-60 Feature you need the HiFi Controller and the attached GPS Antenna.
New Service code (Yellow-7) is available: 321(service code - white menu) will initiate a special mode called “Zero to Sixty”. This mode will temporary turn your ALP system into a performance meter (like a VBOX) able to measure your vehicles acceleration time from 0 mph to 60 mph. Mode only works if GPS Antenna is connected and if HiFi Control Set is used.
There are some bug fixes like the Front/Rear LED & Alert issue as well as some important changes to the DragonEye algo which is very important to anyone that experiences these guns.
cheers they are alive in Melbourne
Details of the 5.1.2 update: (05/06/15)
Control Box Firmware update: Release 5.1.2/6.2
1. Important laser performance improvement! Update highly recommended.
2. Various bug-fixes and stability improvements (Voice, GPS, etc.).
3. Enhanced Pro Mode - LED's will now react to signal strength even during Voice announcements.
4. New Service code (Yellow-7) is available: 321(service code - white menu) will initiate a special mode called “Zero to Sixty”. This mode will temporary turn your ALP system into a performance meter (like a VBOX) able to measure your vehicles acceleration time from 0 mph to 60 mph. Mode only works if GPS Antenna is connected and if HiFi Control Set is used.
New Firmware & Voice Packs are online now. Please update and let me know if you have any issues updating.
Hey for everyone, since in the past the up dates took a little while to up load to the cpu, this one takes a little as well.
So be patient, mine took about 3 minutes and it felt like 10 lol
Just let it go u till you get the blue flashing light and when it goes out you will get a beep when it goes off and youre all set.
Tom if im wrong please correct me... this was how my update went
EDIT: Tom i went thru all the steps and re down loaded all the new software and all i get is parking mode, It will not go into defence mode...? Anything
All completed, now I have whether its a Front/Rear ambush lol
Ok i guess the 3rd times a charm... tom when im in silent power up did we loose the (active) all i get now is a beep with a blue light.. when im not in silent power the audio is that as it has always been?
