Good lord that is allot of fake registrations! If I switch from east coast server to Florida server it let's me on lol.
Firmware version 4.3.6
Region Australia & Pacific
Power Cycles 327
Control Set FW version 1.3
Control Set HW version 4
is the above correct
no showing the control set 3.2
Updated no problem, thanks all
no gps working spent hour messing around, does any one test the oz f/w etc before release also cant up grade controller been on test, k band not working properly, gps is enabled in set up
Power Cycles 327
yes, and i have all ways up dated every thing before, they were a copy and paste from my stats i pulled
disconnected every thing direct to controller no bt no rg, tried the controller up grade,nothing has changed still the same,
Power Cycles 381
Control Set FW version 1.4
Connected sensors
Connected sensors when manually memorized Front1, Front2, Rear1, Rear2
Connected sensor (actual) Front1, Front2, Rear1, Rear2
Settings
Audio Volume 5
Parking detection range 1
Silent Power-up Disabled
Dark Mode Normal
Parking enabled sensors Front1, Front2, Rear1, Rear2
GPS Antenna Enabled
PDC Speed Limit NONE
Working mode Parking and Laser Interference Defense
Pro mode Disabled
LID Speed Limit NONE
Radar Antenna Model STIR+
Radar Settings K, Ka
LID Time 6 seconds
Specific LID settings
Vitronic Poliscan
Speed scanner Enabled
Unicam Camera
Section speed control All sensors ON
NJL SCS
Speed-laser Enabled
Riegl
Speed-laser Enabled
Trafic Observer
Stalker
Speed-laser Maximum Power
Alerts by Source Speed-laser
Marksman and UltraLyte 19
Atlanta SpeedLaser Stealth 0
Kustom ProLaser 1 0
Kustom ProLaser & ProLite 0
Redspeed SpeedGuard 0
Riegl 0
Stalker 0
LTI Truspeed 2
Unipar - SL700 0
NJL SCS 101 & 102 0
Jenoptik – Laveg 0
Leivtec XV 2&3 0
Laser Ally 0
Error Sensitive Lasers
Jenoptik LaserPatrol 0
Jenoptik TraffiPatrol XR 0
ProLaser 2 & Atlanta SpeedLaser 0
Speed Section Control
Camea - IR Camera 0
Speed Scanner
Traffic Observer 0
Vitronic Poliscan 2
Radar
K-band 248
Ka-band 8
X-band 0
POP 0
MultaRadar CD 0
with this controller f/w farked up if i go back to just laser and the plus, will the laser work on bt,
just one thing when i try to do fw on the controller it gives a kwik double chirp right at the end of up grade, some how seems as though its stopped short of doing the full upgrade like it gets cut off
Dinkydi, I am going to email you one of my Control Set files... Please let me know if it gets you closer to 3.0
Sent from my SCH-I605 using Tapatalk
