Yes thats what I was thinking about doing next. I hope its the cable I would hate to have to change the sensor but we will do what we gotta do.
I will let you know what happens.
I am very happy it is just cable and not the sensor. Outwise I would have had to rip sensor out, relevel new one etc.
Sent from my SCH-I605 using Tapatalk
Thank you!...
I tried going out and cleaning pin sensors to the other side as well with no luck. That is very strange. Everything on the cable appears to be perfect. I love these cables too nice and thick and quality looking rather than just a telephone cord.
Glad we found the prob tho. Leave it to me to get something bad. I am probably your first problem with anything. Lol
I notice this unit seems more high quality than any other .
After firmware has been loaded I am assuming that it doesnt really "reload" the same firmware. The reason I ask is because I went ahead last night and redid all of the files and process and it did not appear to load firmware like it did the first time I think it loaded the setup file though
Might be pinned wrong on the modular connector end. If you have a crimping tool you can cut the end off and put a new one on. I will replace it either way but if you are anxious you can give it a shot if you have a crimping kit.
It will check the firmware and determine if an upgrade is needed. Since you had it installed already it wasn't necessary.
Ok thanks for all the help! I dont have crimping kit and I would probably just mess things up. Not sure which wires go in what order anyway. I will probably just wait for new cable. By then maybe I will feel like working on it anyway.
