I think you will need at least one new ALP head.
some will have good and some have bad experiences with companys ...once you have had one bad and makes it worse the first bad experience you wont go back take example the entire of Australia wont purchase blinder ..even the rep him self stopped selling blinder here in Australia WA so that tells you something ...
maybe leon was good to you but where was he when blinder stated they jam the poliscan even showed on there website for perfect install against this threat ie showed how to mount heads (angles ) etc
then when one questioned another there reply was 2 weeks but then 2 weeks turned out to be exactly 2 years for an update (and im not joking) ..
.turns out that they have did an update but to late to test because no one runs the 905 no more to test ...the ones who run the 905 are still shit scared to test ie first bad experience
all I remember when the blinder released there new jammer they all hyped it up.... but went into hibernation went things went south for them
sorry to be blunt but no one here should compare AL with blinder its like comparing a lambo with a Hyundai getz or even worse a hybrid
THAT is NOT a true statement,Vortex!
My original HP-905 CPU bought in June when they were first came out went up in smoke 5 mo. later in November.Leon was very good & quickly sent me a new CPU.I requested feedback (from Leon & Blinder.dk) on what the failure cause was & even included a drawing of which SMD part on the ckt. brd. was toast.
I asked 3 times within 6 mo. of the failure for feedback on what happened after its autopsy.
It's now been 1yr & 5 mo. & I'm still waiting for the answer............................................ .................................................. .
Yes, You will need atleast one AL Priority head in the front and back. The system can not consist of all G9 heads to work against the compact. Personally I would try to swap all heads overtime to ALP heads as they are superior to the older versions.
Frankly, even if dragoneye creates the unjamable gun for 'smart' jammers, a Lidatek LE-10 will have it for breakfast, which is from the dinosaur age.
You can randomize your pulse rate till your hearts content, but a brute force jammer will be effective against ANY pulse rate.
Sent from my LG-LG855 using Tapatalk 2
The Le-10 really didn't do all that great against the dalas when I did testing.
