What version stalker did you get. I know it was probably a used one from the usual sources. Was it an old 3.5?
I haven't the slightest clue, I know it was almost brand new when I received it, apparently it was his backup lidar that he rarely used. Manufactured march 2008.
After receiving some good advice from KrpA, possibly turning the Maximum setting on will fix the PT's.
I still sent AL a recording as the Camea thing has me wondering?
Attachment 971
ST - Isn't yours an Aussie version, which is actually the EU version in km/h if that makes any difference ?
Camea falses - I had two in my logs on retail release firmware, but I also got two a couple of weeks ago on 4.3.4 firmware just after dark, but put that down to a motorbike headlight that was behind me. As KrpA says, they shouldn't really be enabled on Aussie regional firmware.
Not sure if this has been answered or not, but after pulling the stats from the CPU, do the statistics reset? Just curious...
AFAIK they don't reset, and there presently is no way to reset them. Hopefully a future update will add this. It would be nice to be able to clear the statistics, especially after a testing session.
So, when you pull stats, save them on your computer so you can compare them to see what "new" guns you were hit with.
Chronological logging would be nice to have. Presently only the iPhone app with the bluetooth adapter can do this.
I was able to follow the instruction and created the setup.alp file on my flash drive. I plugged the flash drive in my computer and went to http://www.alpriorityupdate.com/Setup and click the browse button, found the file file and clicked upload.
I can see my current configuration settings but nothing about any stats. What am I missing here?
