Can you elaborate on #4. A new self-test function added, checking if the system is properly configured. What exactly is checked and how and where you get the results of the check?
Thank you
Going to update tomorrow (Canada Day holiday!) To recap: I do the factory reset FIRST, then add all the new files from the USB like normal?
Install the firmware and you will probably get the error which will reset the defaults automatically after the update. Just make a new config.alp file from the alp update site and keep it on the drive and it will load it when done with the firmware and you will not have to do anything but insert the drive with the firmware and configuration file.
I just upgraded my setup to v5.2.5, and everything seems to be working as expected (my laser tester is setting off the voice alerts and pro-mode tones).
But I'm curious if the behavior has changed, or if my memory is wrong, or maybe I did something different when creating the new settings file. IIRC when I would hit the left button on my HiFi module it would give me a double-beep and turn green, indicating parking mode only. Now when I do that it says "muted" and stays blue. Did something change with v5.2.5 or am I losing my mind? :)
Here are the settings I changed from the defaults:
Dark Mode - Dim
Status LED - Constant
Advanced options - PDC & LID
Pro Mode - Enable
LID Time - Unlimited
After LID timeout - DLI & Warm-up
I just started my car and hit the left HiFi button again (without firing the tester) and it still says "muted" and stays blue.
It looks like I was wrong and it was a single press of the Menu button that put it in parking mode only:
https://www.youtube.com/watch?v=83DGLOGJ1mk
But when I press the Menu button a single time nothing happens now.
