Probably could be done using a code only unlimited setting with new purchase.
Good point Tom, 9 seconds is way to long. Maybe having it set to a lessor amount from the factory will help prevent JTG. In my opinion, maybe 6 seconds should more than enough.
9 seconds is, for all practical purposes, a JTG. Let's say you're cruising along at 75 mph (110 feet/sec) and a LEO hits you from 1000' away. In those 9 seconds you're basically on top of the LEO (okay, not really, because you've slowed down a bit). But it's super suspicious AND for any shots 800' away and less it's likely a JTG anyway. Unfortunately, 9 seconds JTK time makes it a real pain to test your jammers if you're cruising along at 25-30 mph on a 1000' long course. I don't see what removing the unlimited LID time would do as it won't prevent people who aren't knowledgeable from JTG in the vast majority of cases, except maybe in really long, 1500-2000' shots, and even then, it won't do anything to remove the suspicion associated with not being able to get a reading for a full 9 seconds.
How about including either a booklet, or a URL, in red, on the invoice for every ALP system that educates people on proper usage? Limiting the LID time is never a substitute for proper education.
I don't think there's much you can do if people are deliberately being malicious. Nothing's going to stop them from circling around, hiding behind other cars, and popping out at the last moment for a JTG, even if their LID time was forced to be 4 seconds. Eventually they'll grow up or they'll get a ticket for jammer use or something else and they'll learn not to do that.
I have observed another concerning operational "feature."
After the unit drops back to "green" mode after hitting it's jamming timeout, not only does it not jam anymore (expected), but it no longer beeps either. That's with pro mode on or off.
Maybe that's another "feature" to protect you from a LEO who may have pulled you over – and would be able to hear the alarm – while another LEO is using a LiDAR. It would give you a minute to disable your jammer before it
No offense, but this is like lining up super models and critiquing their looks. These are the best LJs on the market that jam the best LIDAR guns on the market. With a proper setup, you are going to be near LIDAR-proof in the real world.
I will agree the 1 min start up can some times be annoying specially my self there is handheld or a poliscan set up 30 seconds from my house ,,,how ever some times it not a bad thing incase you get pulled over at least if the leo asks what they are and takes a shot at them he has minute to work out there jammers ,,refering back to one of your other posts I have set my ultralyte in survey mode ,,,,in survey made the gun will take distant reading basically all the way down to zero ft ,,,standing 5 ft 10 ft 15 ft 20 ft the ALP will alert and jam even though the lidar beam is so tight
stick to your ALP mate its the best jammer made to this day
