Just noticed there is no RDR option when you select Net Radar as the detector unit.
ok just wanted to make sure it was disabled, that's all.
Now I'm getting GPS antenna disconnected and rear radar antenna disconnected alerts. I've unplugged each and reseated them but am still getting the alerts. I noticed the green light on the RG3 module is not lit.
GPS Antenna needs to be connected to RG3 Module's GPS Port and Antenna 1 in the Front 1 & Rear Ports if you have both antennas. You also need to activate both on the setup page. Each antenna was tested before shipping so you have a configuration issue. Did you also connect the Power Splitter cable?
I'll check again but I know for a fact GPS is in the right spot. I asked about it on RDF.
Lmao! The cable from the control box somehow disconnected. All is well now! Lol
So glad i got the BT module Ver 2.0 I just downloaded the APP connected to module FW update done OTA. All done and complete in less then 10min.
