VoicePack name as well as all file names are always the same. They don't change.
Done 5.2.2 , easyly as usual. Had to re-install the config file.
Thanks Tom & Alp Team.
Where did you get the update from already..I don't see it on the ALP site yet and have not received the update notification from ALP either....you are privileged :) ?
Hmm..I still only see 5.2.1
http://www.alpupdate.com/Firmware
okay thanks Tom
Something odd is occurring..I didn;t think my unit was updating so I pulled a stats.alp but I didn't get a stats.alp file I got a setup.alp file...which I uploaded and gleaned info from..which tells me my fw ver is 5.1.3 and 3.5
This seems very odd as I usually always update regularily
CPU hardware ver 1...1561 cycles..control set FW 3.5..hw 1
Am I doing something amiss as to why the fw will not update properly...do I need a default reset...how many fw versions am I actually behind from 5.1.3 to the current 5.2.2
I'm using a new 64 gig usb3.0 Sandisk memory stick
tia
ALP has not used setup.alp files for months. That file was probably still on your thumb drive or your firmware is quite behind.
You are using an incompatible thumb drive, it needs to be a USB 2.0 drive and smaller than 32gb.
