10-4
I'd probably already have bought an ALP but I don't like the control pad.
I'd like to see something with actual buttons akin to the Bel STi-R or just simply have a remote speaker and a toggle switch like the LIs.
Auto connect with the BT
It does auto connect, It was just this one time (That i know of) that it had happened, If i had NOT notice i would have gotten tagged, i was hit 3 times with Lidar that day.. To me its just a safety per caution and really wish that it wasnt so hard to just add something like this to the program....
Are you sure because I believe I have to go into the app and hit connect four it to work less if I'm mistaken
Right I understand but as you said you have to tap the app so every time you get in the car you have to hit the app it would be nice if it would just as soon as you turn on the key and the phone is on it would connect
If you leave the app on all of the time, and leave it in background mode, as soon as you start the car it will auto connect. You don't have to launch.
Guys if.you want to discuss how this works start a new thread this thread is for future AL requests only
Are there plans to move production to China to bring costs down and help with increased adoption and market share gains?
Why would they? Croatia is the China of Europe. Production costs are about the same...
But there would be a noticeable quality difference....
Croatian made products are of higher quality.
Also the cost you are seeing is the after sales ongoing support.
Sent from my GT-I9505 using Tapatalk
Name the statistics file something other than SETUP.ALP, so that it doesn't keep obliterating my configuration file on the same USB drive.
Android BT is what I want. I despise apple and there os and refuse to own any apple products.
What about a option to turn the Big red MPH Zero Off? I know the peeps with an Iphone with GPS that actually works like it, but the ones that use an Itouch that cant utilize it and always seeing a big Zero all the time, it would be nice to turn that feature ON/OFF if we wanted too?
Very simple request:
Change 'Dim Mode' so that the LED is constantly illuminated with a lower level of intensity. The blinking light is obnoxious and I like having visual confirmation that the unit is on and working.
Also consider changing 'Dark Mode' so that you get a chirp when the unit finishes warm up and goes into defense mode. In dark mode, you have to enable the star-up tone in order to get audio confirmation that the unit is working.
Just a couple of features I would like to see added :)
ALPconnect
-digital compass on the main screen
-recent alarms disappear when in parking mode.
-it checks and compares firmware and let you know of an update
-as well as segmentation, distinctly different audio alerts for each segment of K, just like KA band is. And the option to full noise alert on those frequencies
-GPS speed trend of the last 10 Mins of your trip, clearly showing where you got hit on the trend.
-support for Ipod with external GPS
-landscape mode
-pass lock the app
-ability to connect to 2 different CPU's at once
-support for the new NoPhoto and incoperate in one app :)
ALP website
-remember your last known setup
-less spread out and more compact format
ALP firmware
-all sensors up front or rear option
-removal of un-used guns that don't exist in Australia in FW, (Dragon is used in Victoria, so No )
-V1 support
-9500ci support ( it can be done )
-improved Redflex detection ( but I think that in the STIR firmware)
-update the STIR via ALP
Does that include the removal of Dragon? No thanks...
What is the point of removing support for ANY guns? As long as having the support there doesn't cause falses, it doesn't hurt anything to have it, even if you never see those guns.
agreed better to have them all
To remove false's, as winter said above ^^^^
I too have had the Camea false alert.
Just want to see all the guns/units only used in Europe only gone, besides Policscan
we could make a list of falses only so they could apply these to our next update camea is one of them ...really wouldn't want them to turn off all guns not used ....my self and winter will sure complain when our pl2 and stalker and other older guns we come across to test with
so if camea is the only false why have all other guns disabled ? would realy hate to see all other guns disabled because of one camea/IR camera
make the list
So I'm really digging the new HiFi module! I've been eagerly awaiting it for a while and am very glad it's finally here. HUGE improvement over the standard beeps. :)
One thing I noticed is that at startup, even if you select the "Silent power-up" and "Skip first warmup" options checked, the ALP still shouts "Active!" at startup. I get that there's two parts, the power-up procedure and then the normal operation of the jammers and that the power-up procedure is independent of the announcement that the jammers are now operational (especially helpful after a JTK), but it would be really helpful to be able to truly get a silent power-up when the option is selected.
A couple people have mentioned that the announcement startles their passengers. For me I run my speakers at volume 5 so that I can hear it while driving and, well, it is very loud when sitting in a parking spot. :D The high pitched beep with the standard control module was also a bit ear-piercing at loud volumes, so a truly silent option would be very much welcomed.
Some people mentioned they like having an audio confirmation so perhaps 3 options would be very helpful.
1) Normal operation with all sounds on at startup
2) Shorter audio startup like we have now to verify that the speakers are working
3) Totally silent option where only the lights light up upon startup
Thanks!
I beat both of you.... LI... AL...
from the top of my head antilaser improvements could be ,,to make a new less advanced jammer ,,just so other companies can have some sort of same level competition LOL
I beat all 3,, antilaserG8 >>antilaserG9rx>>blinder>>> laserinterceptor then back to antilaser>>ALP all in a space of 7+ years ,,denolix tested out my G8 and G9 and at the same time I picked up a m18 laser jammer never used for realife tests just a spare jammer for test days to compare between a high end jammer
Yep u sure did, deano
allot of people are forgetting dinky ,,back when the AL G6 or i think the G7 came out I think somewhere in 2005 to 2006 it was the winner from GOL (GUYS OF LIDAR ) ,,the only reason LI became king was that they had retailers world wide,,or should I say in the US ,,antilaser was only a Europe only thing and was not well known on US websites or forums
another thing that antilaser really needs to look into ,,,,,,,is that here in Australia we don't just have tim who sells the ALP ,,we have a car stereo shops also selling the ALP im sure tim will be the supplier for these shops ,,,
I get asked a million questions about the ALP ,,one of the questions was how do we update the ALP,,,, so you can just imagine what other questions they asked specially when it came to the dragon ,,,the same shop use to sell the G9 ,,they only found out about a year ago how to get into some features IE constant mode as now they have there own laser gun for testing ,,as for me these guys at the stereo shop are friends so I keep them in the loop ,,,but I shouldn't have to
and these guys sell them ,,I think a better tutorial should be explained ,,specially if they selling the product
