cheers they are alive in Melbourne
Details of the 5.1.2 update: (05/06/15)
Control Box Firmware update: Release 5.1.2/6.2
1. Important laser performance improvement! Update highly recommended.
2. Various bug-fixes and stability improvements (Voice, GPS, etc.).
3. Enhanced Pro Mode - LED's will now react to signal strength even during Voice announcements.
4. New Service code (Yellow-7) is available: 321(service code - white menu) will initiate a special mode called “Zero to Sixty”. This mode will temporary turn your ALP system into a performance meter (like a VBOX) able to measure your vehicles acceleration time from 0 mph to 60 mph. Mode only works if GPS Antenna is connected and if HiFi Control Set is used.
New Firmware & Voice Packs are online now. Please update and let me know if you have any issues updating.
Hey for everyone, since in the past the up dates took a little while to up load to the cpu, this one takes a little as well.
So be patient, mine took about 3 minutes and it felt like 10 lol
Just let it go u till you get the blue flashing light and when it goes out you will get a beep when it goes off and youre all set.
Tom if im wrong please correct me... this was how my update went
EDIT: Tom i went thru all the steps and re down loaded all the new software and all i get is parking mode, It will not go into defence mode...? Anything
All completed, now I have whether its a Front/Rear ambush lol
Ok i guess the 3rd times a charm... tom when im in silent power up did we loose the (active) all i get now is a beep with a blue light.. when im not in silent power the audio is that as it has always been?
