All it requires is a number (gun type) stored in a single register x 5
That gives the gun type for last 5 hits. No time or date stamp is required in the same way that ALP stores the counter for each gun type.
I have changed my front and rear install several times and my CPU is buried in my dash where it's hard to get to. My car didn't do so well at a recent testing event so I wanted to ensure my middle head was plugged into F2. Do I had to take my dash apart and bring the CPU out to confirm...this took about 30 minutes.
That gave me this idea: wouldn't it be nice if there was a yellow menu option where, when activated, instead of beeping when you put your hand in front of a sensor (cause it's s parking sensor) it would audibly say the name of said sensor? It would say "F1.....F1.....F1" or "F2...F2...F2". Etc. That way one could turn their car on parked away from any objects and check that their heads are in the correct port without having to take anything apart.
I think this would have to be only for HIFI and BT users.
What do y'all think?
I think this would especially be useful for people who have their jammers professionally installed and need to check this. They might not even know where they're CPU is much less how to get to it.
Recently I bought a Apple Watch, and there is quite a few apps in the store that have support for the watch to display notifications.
Would it be possible to add it to ALPConnect iPhone app? And a simple gesture like a wrist twist to mute alerts
I know this can't be implemented on the current ALP even on a hardware update, however when the next generation jammer comes out maybe in a couple of years? Connectors the way they are at the moment are quite large and do not fit through grills, it would be really great to see a skinnier connection, wil it would be great to see a standard USB connection I understand, though there must be some compromise option between the current large circular connector or a miro-usb as used on stinger laser heads on LAB-14's.
While I could make the current ALP head fit with grill mods, I would really prefer not to have to mod my grill.
geez u must have very narrow grills even when they are tight the plastic will give a little, though i aint seen the very latest mine are the din type
