X2
Wow...that was EASY! My update took no time at all!!!
Where might we read up on the items of this upgrade..more specifically 2,3,4,5,6,7 ?
just got this email from alp
Latest firmware updates
AL Priority - Control Set Firmware update Report
Release 3.1; 10.04.2014
AL Priority - Control Box Firmware update Report
Release 4.3.5/4.7; 08.04.2014
is this what we all ready have or is it a later fw for control unit etc
yeh but look at the control set up date 3.1 10/04 2014, here is the full e mail
1. GPS speed feature added. Compatible GPS receiver and ALP R/G Plugin required (contact your distributor for availability).
By combining your ALP with a R/G Plugin and a GPS Receiver you can now achieve enhanced filtering options (also online at alpupdate.com) by speed of travel. PDC alerts and Radar alerts can be cut off by crossing the set speed limit. LID defense can also be cut of below set speed limit and converted into detecting only.
2. Added support for Laser interference defense (LID) against new ECCM lidars. Patent pending technology!
3. Fixed Error2 bug on start-up, other stability fixes.
Sometimes on start-up the system indicated Error 2 for no reason (usually if there are obstacles in front of ALP sensors), bug fixed; other stability fixes.
4. Poliscan False Rejection user selectable option added. IMPORTANT: Feature does NOT work with ALG9 sensors.
Poliscan false alert rejection if enabled will significantly reduce the number of false Poliscan alerts but as a side effect maximum detectable range will be limited to some 700 meters (Poliscan does NOT measure beyond 80 meters).
5. Skip first warm-up - New user selectable option added.
If enabled the initial 60 seconds warm-up will be skipped but other warm-up periods (after LID alert counter times out) will remain.
6. Start Ka alerts at Full strength - New user selectable option added.
If enabled all alerts on Ka band will initially be signaled as if they were a full signal strength alerts (for first 3 seconds).
7. Demo mode feature is added, service code 1-2-3.
When activated the ALP system will for 60 seconds go through a demo mode playing its range of Laser and Radar alerts.
8. Control Set Firmware update 3.1. Added new sounds.
Copyright © 2014 Radikal, All rights reserved.
Our mailing address is: info@alpriority.com
unsubscribe from this list update subscription preferences
Email Marketing Powered by MailChimp
There was an issue where on 4.8 the Control Set firmware was still old. It was corrected on 4/10 when it was realized. If you are using the Control Module and you want the latest sound files you can update the Control Set firmware at any time.
thx, dont use the control set , only BT so no need for me to up grade the control set
just got email new up date from dgc, no link so it.s on the way :thumb:
Guess the new firmware is incoming, news annoucement from AL ;
http://www.antilaser.info/?p=704
alpupdate.com appears to be down as well ?
Site being down is a server issue and is being taken care of... Has nothing to do with the firmware update. Firmware update will be released tomorrow 6/5 as scheduled.
Yes, ALP Connect 1.4 was submitted to Apple and it could take a couple or days or up to 2 weeks to appear. It depends how many apps are in the queue waiting to be approved.
First Post Revised and download will be available tomorrow
Details of the 4.3.6 update (6/5/14)
1. DragonEye DALA Laser gun support extended.
2. Leivtec XV3 support added.
3. Stalker XLR Anti-Jammer support added.
4. Various LIDARs code improved.
5. Support for new ALPConnect version 1.4
6. USB functioning further improved.
Incredible
:whoo:
So, just to confirm I have the most current items uploaded:
CPU firmware version 4.3.6
Control Set firmware version 3.2
New update being update by Friday. More of some minor improvements and support for new Laser used overseas.
1. Robot Traffistar S350 Laser scanner is now supported.
2. Code is improved for various other LIDARs.
3. Error signalization when using theft lock did not work properly, bug fixed.
4. Update for Control Set now can be inserted into USB at any time or at power-on like before.
5. Functioning of a USB port has been additionally improved especially on start-up when reading the USB TheftLock keys.
Seems to be live already ;
http://www.alpupdate.com/
Haven't downloaded yet, and the firmware page still references control set 3.2 firmware ;Quote:
13.8. Control Set firmware update rev. 3.3!
1. Control Sets update mechanism now works on a broader choice of USB drives. Update USB stick can be inserted at any time during operation, or at power-on.
2. K band sound intensified.
13.8. Control Box firmware update rev. 4.3.9/4.9!
1. Traffistar S350 Laser scanner support added.
2. Various LIDARs code improved.
3. Error signalization in theft lock mode bug fixed.
4. Updating process improved for Control Set.
5. USB functioning further improved.
http://www.alpupdate.com/Firmware
Will download in the morning (nearly Friday here now) :)
Just downloaded my 2 x CPU firmwares and the UCSET.bin for the control set - all different file hashes to 4.3.6 firmwares and control set 3.2, so new firmware is live now :)
Hey Tom, did the small bug with swapping between detection & defence get fixed? Be nice to plug defence in and not have to stop or cycle power :)
I was able to download the new firmware for the control box.
but the control set firmware has not been updated on the website yet?
I just got an email said everything is a go--so start the downloading :)). Thanks ALP
yup just got my notice..all ready to update two
Yep same here in Oz
After update it seems it takes an awful long time until the green car changes to blue..do i have to reload my user settings file ?
After update it would default back to default settings of 4 Second LID time w/60 Second warm up. You need to reload your settings file with your preferences after the update or keep your settings file on the USB drive and then it will automatically reload after each update.
Just did mine! All good to go.
Got it..reloaded setup file and gtg !
Expected out tomorrow sometime is update to 4.4.1
Details of the 4.4.1 update (9/15/14)
1. Status LED can now be a permanent light as well as blinking (flashing).
2. Improved self-test routine.
3. Improved and expanded various LIDAR routines.
4. Various bug-fixes.
There are several improvements for some US guns and this update is highly recommended. If you have not updated in a while please make sure you upgrade to the new 4.4.1, Look for its release in the next day or so.
Thank you Tom and the ALP team!!! :)
4.4.1 is live but description online has not been updated yet:
Attachment 2570
