Unfortunately no... The system is legally sold in every country as a parking sensor system and the user manual reflects this.
thats cool :thumbs2:
Thanks Tom
I already have the STiR-O
The reason I am considering using it up front with the ALP is that it is my understanding (from reading here at the forum) that the "O" a better antenna than the STiR plus.
I assume that advantage will still be true when integrated with the ALP.
However I did not realize TSR woud not be available. I assumed it was a feature built into the CPU as opoosed to the antenna
What think you?
Not trying to force my idea to be a good one BTW
Simply hoping to learn
IN CLARIFICATION
The system would be
STiR-O integrated with ALP ( "0" antenna facing forward)
STiR plus- separate system, ( Antenna facing rearward) + GPS
Thanks
Ed
The Antennas are full radar detectors.. There was no TSR option when the Sti-R Original came out which is why even connected to the ALP there will not be any TSR filters and they will false alot.
Is anybody that install both ALP integration and STiR plus with the same antenna?
I just installed my ALP system and attached the Escort 9500ci antenna. In the setup page on alpupdate.com, which detector do I configure: STiR or STiR-M
STiR-M is for the 'MultaRadar' editions sold in Europe where the MultaRadar CD / CT is used.
I'm assuming your from North America, and bought your 9500ci there (MultaRadar not used), so just select 'STiR' :)
Hope this helps
Hello
I am considering integrating my STir plus with my ALPs via the RG module
Questions
- Will the STiR plus alerts play thru the Alp Hi Fi system?;- and thru the Alp Connect on my i-phone when in use?
- When putting the ALPs into Parking Mode Only( either via "force parking mode" or Setup mode) will the Stir plus also be turned off?
Thanks
Ed
