I'm waiting to see how well this works out with the controller(muting, lockouts, etc). I'll be placing an order really soon.
If your looking for Lockouts you will need to get your own full Sti-R Plus. Lockouts are an Escort patented feature and you will not get them with the integration. The Integration will basically operate as a RDR/BS Redline with the AL Priority and mixed with Saavy if you add the GPS to ignore alerts under a certain speed all in one unit.
Hi Tom,
If you want to use the radar module and bluetooth module at the same time, can you daisy chain the modules together to plug them into the single C port of the CPU, or is there a splitter or pass-through type cable arrangement to hook them both up ?
Did you get any updates on which GPS antenna we can use ?
Many thanks
Radar Module connects to the Radar & GPS Port, The Bluetooth Module gets connected to the C port.
No answer yet on which GPS antennas will be on the supported list yet.
If I use the bluetooth module for the initial install with 2 front sensors, will I be able to add rear functionality in the future? Will the bluetooth module and CPU both recognize the additional sensors? Is there a potential delay in alerts when using Bluetooth instead of a full hard wired system?
Thanks
Only if we could connect the Gps to both systems usuing the 1 airieal
