^ - This is what I do also,dragons !
I keep my "Set-up" file for Defense on a separate USB flash drive & anytime I do a f/w upgrade I always reload the "Set-up" afterwards.
Tom,
If you read the bottom of that post it does say you need to rename it to Setup.alp, I switched the extension to .txt because you have vbulletin configured to only accept jpg, gif, txt etc all the usual attachments and nothing non standard, it is actually a ALP setup file if you download it rename it accordingly and upload it to alpupdate.
Just mixed the words around.
I think there are limited areas that do.
The Gatso24 has a slightly higher power output then a Redflex.
So if these changes have caused the Gatso24 to act up, then anyone that has to deal with Redflex will be in the same boat...
Started to run the Redline again.
God its so annoying compared to the ALP haha.
Videos coming in a sec.
BA, have you any vids with your Bushnell K band radar, might be worth recreating them to see if any range has been lost.
I would but stuck at work.
The ALP/STiR+ has struggled in the past with Redflex detection, only really picks it up when you right ontop of it, the redline in the same spot gives me 300mt warning
Dragons and I did a few laps of this camera.
Same result every run.
http://www.youtube.com/watch?v=yFErjQ6fg60
