that's true, just have to keep peeper's sharp and report
Well researched. I got caught up at
I think that means if you're only high on (3,4-methylenedioxyamphetamine; tenamfetamine) MDA, then you're fine to drive?Code:"prescribed illicit drug" means—
(a) methylamphetamine; or
(ab) 3, 4-Methylenedioxy- N -Methylamphetamine (MDMA);
(b) delta-9-tetrahydrocannabinol;
The full list for VIC is at http://www.austlii.edu.au/au/legis/v...09289/s41.html
Good to see the prolaser ii is still good... although not sure what it means by "auslaser", mine shows it's display in km/h but it says nothing about auslaser
Code:ROAD SAFETY (GENERAL) REGULATIONS 2009 - REG 41
Prescribed speed detectors
For the purposes of the definition of prescribed speed detector in section 3(1) of the Act, the following speed detectors are prescribed—
(a) a digitector; and
(b) the following laser devices—
Reg. 41(b)(i) revoked by S.R. No. 118/2013 reg. 4(1).
(ii) the Prolaser 11 Model Auslaser;
Reg. 41(b)(iii) revoked by S.R. No. 118/2013 reg. 4(1).
(iv) the Prolaser III;
(v) the Pro-Lite;
Reg. 41(b)(vi) substituted by S.R. No. 118/2013 reg. 4(2).
(vi) the Pro-Lite +;
Reg. 41(b)(vii) inserted by S.R. No. 118/2013 reg. 4(2).
(vii) the ProLaser 4 (also known as the PROLASER 4);
Reg. 41(b)(viii) inserted by S.R. No. 118/2013 reg. 4(2).
(viii) the DragonEye Compact (also known as the DragonEye COMPACT); and
Out of the list of guns I would watch out for Prolaser 4.
