the reason I was wanting to know about heads getting warm was first I never seen this before on a jammer and 2nd of all im on my 2nd cpu as my original cpu would not power up ...
my first thoughts was that I may have some defective heads drawing to much power hence my first cpu
it has put my mind a rest knowing that ALP heads get warm
my theory would be that the capisitors and circuitry sit closer to the inside of the housing hense heat soak
my G8 and G9 heads don't get warm probly because the housing are so much bigger the circuitry is further away from the inside of the housing
all of AL products work as a full time parking aid so for the ALP its nothing new ..I use to allways think if I switch off parking aid it will save diode life as its not scanning but cheked this out many years ago with IR
BRD while you got the IR camera on hand as I have to strip out a cuboard to find mine and charge it up but try and do the same test one during the day and one at night
I cant remember witch one I tested but the G8 or G9 flashed a different sequences day and night... system still worked 100% not to sure if the ALP will do the same I figured it must change a scan pattern for different lighting senarios like I say im not to sure if the ALP will do the same AL may of changed a few things
