It's all in here: http://www.alpriorityupdate.com/Faq
Click on "What are the service codes?"
Thanks once again. This may be the way to go for me
regardless how many protection codes or GPS modes do you think a cop is going to perform a test there and then on the side of the road ?
when one JTG to many times the side cutters come out and the system will be removed on the spot
i have a friend here in perth ,, jammers are legal but when you upset the cop to many times it may or will just land you in court and the system was cut from his car he was using the stinger with a set speed limit
as for me been using AL and other jammers for 7 years only becouse they where used correctly
if the AL cpu is registered to you they can remove lock keys ETC,,, but if i was to take your CPU and get it unlocked they will tell me to F@@@off
what if one travels over seas and the cpu is locked to a region where do we go from there
It depends on where you are located and how LEOs respond to jammers.
In most areas, as long as you use them correctly and JTK, you won't run into any problems.
Where parking-only modes are useful is if you get pulled over (even if not for jamming) and they notice the sensors and inquire about them. "They're parking sensors, Officer."
In some parts of Virginia, LEOs are aware of jammers and will shoot a car that they see heads on even if they're not speeding, or stopped in traffic, to see if they are jamming, and they get pulled over and ticketed if they are. Switching to parking-only or detect-only mode prevents this.
I'd like to see 2 new features added to the Android version. The first implement an option for the app to return focus of the previous app when an alert is presented after a predetermined amount of time so that you don't have to hit the back button to go back to the application that was on the screen before. Secondly control of the new profiles that we were just given with the firmware update specifically so that we can change the radar modes.
A big thank you to everyone that responded over the privacy key situation - I now have that up and running with a quick pull usb drive should the need arise. A really great feature.
I now have taken delivery of the HiFi Controller and was about to re-install my gear using this however I have read that I will lose the pro-mode beeping/flashing on targeting. Is there any chance in the future of creating an amalgamation of the two such that there can be a quick snappy voice alert followed by audible and visual pro-mode targeting data?
I'd love to have the voices on my ALP but think the pro-mode setting is brilliant.
Thanks Tom.
I've just switched over to the HiFi module, speaker placed in the central tunnel right beside me when I'm driving. Update to new control set and voice-packs took 5 mins or so and ended with a very pleasant lady telling me the data had been uploaded.
Pro-mode works like a charm with the voice announcing the gun plus front/rear designator, followed by the same led and control set beep response as before and now with an added sound form the speaker.
Excellent stuff, I've fallen in love with my ALP. :o
Another request!
Any chance of having the ability to set PDC front and rear to different sensitivities? This is because that when in traffic my ALP goes off when it obviously sees its own reflected signals off the number plate of the car in front.
I actually would like the rear sensors to be set to a higher sensitivity then the front
