I think Google usually offers updates for their devices, but just in case they don't for your version, look it up on xda-dev. Read how to install a recovery like twrp, then flash the latest stable version of slimrom (can be found on slimroms.net).
Are you good with Android? Problem I am having is BT 4.0 LE, I have tried many external BLE 4.0 Dongles and Android just does not have drivers for them and its a waiting game trying to get Google to add support for 4.0 USB BT Adapters.
https://code.google.com/p/android-x8...detail?id=1499
I installed the latest version of CyanogenMod and will test it out and see how it goes. I wanted to use Escort Live on the android also but I have the iPhone version of EL so that wont work. Not sure why Escort had to make two versions of the cable since their Max2 works with IOS and Android. If ALP BT can be used with both then Escort should take note. Not really happy with the development of EL or Escort support for that matter, but I digress.
General concensus is that EL is vastly better on iOS. They probably went with different dongles for each OS because of the bt versions in effect at the time of development, much like Valentine did the same. ALP benefited by developing for bt le from the start.
New ALP Connect Update is available in the Play Store... Not anything new but added a bug fix which effected some Nexus Phones on start up... Thanks to forum member EBS for being persistent with me to get me to listen to his suggestions for a fix for his Nexus phone.
Is anyone else experiencing slow animations. Eg the car switching colours on alert? Or a touch delay?
Phone is just a cheap LG dual core with BT4.0 and Android 4.2.
Have not seen this issue on my S4 or Note3
For the beta, even if you had the package file, it wouldn't install on anything less than 4.4, giving some sort of spurious error such as 'parse error'. I'm sure that the Google Play Store will not let you select and install the app if its not compatible with your device.
any news on when you will release an app for tablets?
