It would be great to be able to assign the 5th sensor as a front or rear so if you configure 3 rear you assign it as a rear and if you run 3 fronts you assign as a front...now that I have 2 fronts and 3 rear the center of my rear will report as a front if it's hit...and I'm not sure what will happen if 2 or all 3 rear sensors reply to rear hit...will the cpu flash yellow and red as a front and rear simultaneous attack ?
