I think this failure was caused by water from a recent car wash I did...I recall concentrating the spray from the want in that area...soon I will rear the sensor apart and have a look inside
Okay to here is the results..it's clear the weather sealing failed..
This is a 4 year in service rear mounted sensor..that from the appearance depicts moisture infiltrating through the lower face/case seam. I do not know if the current units are fabricated the same or if this particular sensor has failed do to a manufacturing defect or design issue...I suppose time will tell if the others follow suit..I'm wondering if this might be considered as a potential warranty claim ?
http://gpchase.zenfolio.com/img/s10/...68258164-5.jpg
http://gpchase.zenfolio.com/img/s12/...68258304-5.jpg
http://gpchase.zenfolio.com/img/s4/v...68258262-5.jpg
http://gpchase.zenfolio.com/img/s10/...68258222-5.jpg
Was the mounting bracket used? Biggest cause of failure is snapping the bracket onto the lens which breaks the internal seal.
Attachment 5646
No bracket..double sided tape along top plane
http://gpchase.zenfolio.com/img/s/v-2/p1095139383-4.jpg
http://gpchase.zenfolio.com/img/s/v-2/p912739603-4.jpg
http://gpchase.zenfolio.com/img/s7/v...33753929-4.jpg
Product is long out of warranty but who is your distributor? We offer our customers that have expired warranties a reduced price replacement at $149.95 shipped with core return.
Sure..I take it though touchless washes and have a Karcher that I use with foam canon at home..but also avoid direct intense spray at the sensors..I understand they are somewhat vulnerable but they also must withstand "reasonable" moisture exposure
