Oh perfect, good to know.
welcome from down under, nice wheels ,shorten the brkt's a tad
Welcome
I would, but I am going to need them that long when I permanently mount them in the spring. You can't really tell, but it is solid plastic in the center of the grill where the crash bar is and where the license plate should go. That is where I am going to screw the bracket into.
If you can hook up with RedRocket, you'll get some first class testing. And a good lunch as well probably ;-)
Question for you guys, do the heads have to be flipped opposite each other? If you look at my pic you will see I have them facing the same way, didn't figure it mattered and didn't want the label showing.
BRD has mentioned before that it doesn't matter whether bubbles in or out.
