Thanks for the input, I will take a razor to the goober in the upper left so it isn't a noticeable eye sore.
IMO, I would replace it, but would conceder using it as a 3 head in your setup, if you have a 2 head setup and get it tested out.
Seriously dont use it. If you can get insurance company to replace it do it. There is no telling what internal damage was done to the head being dragged and having it bouncing around on the ground. It might fail if it has not failed when you need it the most. I would not trust it even if it was in perfect cosmetic condition.
Not even as a third head?
Ok that makes sense now.
