Originally Posted by
awj223
I don't know, the only thing a constant LED tells me is that the system is powered up. But it doesn't tell me that the CPU is still running. Assuming that the blinking LED is controlled by some process on the CPU, the blinking action to me indicates that the CPU is actually doing something (the watchdog timer is firing, the CPU is switching the LED on, and then off). But a constant LED? Well if the CPU were to hang, wouldn't the LED simply remain on? Knowing that the system has power is not the same as knowing it's running. That's why I'm probably just going to keep on using dark mode. If I want to confirm it's running, I'll hit a button and make sure it responds.
