BRD, could i use the LI switch thats already custom cutout in my car? Attachment 2168
i know i wouldn't need all wires, (mute etc) - red for power another for ground? (if you know)
edit
you guys will work it out
edit
okay thanks ! other 2 wires i will just cut and put electrical tape around and leave alone. now to toss a curve ball in, if i wanted to keep LIs in the rear, all id have to do is splice the gray wire with the LI/ALP power?
edit
Err...that's backwards. An "open" switch is one whose electrical contacts are open, e.g. not touching, and does NOT allow current to pass through. When the switch is "closed", the two sides of the switch are electrically connected, and allow current to pass. It's more like a drawbridge: in the "open" (up) position, nothing can pass, while in the "closed" (down) position, traffic can flow across the bridge.
yes you have me there ..but it was a figure of speach ..im geussing your going to now give me wrong for my spellig mistakes
very funny how you guys come out the wood work WOW .......all stay silent untill some one fucks up (CALL YOUR SELF GURUS )
instead of criticizing me WHY DONT YOU HELP THE BLOKE OUT ..I WAS USING THE DOOR SENARIO AS I WAS THE ELERTIC CURRUNT
im geussing im no good you now you can now take over ..to be honest i now cant remember if it was the green or red wire i was going to state that i will post pics of mine BUT NOW I DONT NEED TO
but since i used the door senario ..you americans even spell colour incorectly any ways there was my help i was going to post pics
why bother .
at the end of the day a switch is basically a door or a gate or a bridge or a gate call it what you want
i had to edit my posts as im colour /color blind i realy cant tell if gray or green they both look the same to me
