Let us know if these instructions above work. And here is the Manual.... Attachment 1829Quote:
Found the thread you were probably looking for. Not sure if it works...
For the 9 button version.
Turn on the gun.
1. Press the “Sen” key.
2. Immediately, press the “SPEAKER” key.
3. Immediately, press two keys at the same time. The two keys are the “LOC/REL” and the “SQL”
That should get you into the internal menu. Be careful here as every button has a different function in the radar.
4. Now you can toggle between KPH and MPH by hitting the “SQUELCH” button.
5. When you have what you desire, PULL THE TRIGGER! That locks the value in
For the 7 button version
1. Remove the 4 screws holding on the top plastic cover.
2. Carefully separate the top cover from the unit.
3. With the unit facing forward as you would use the radar, locate the two jumper pins on the left circuit board. They are at the front of the unit, on the top.
4. Short the two pins together and power on the unit, then remove the jumper.
5. The LCD should read one of the following SEn 13, SEn 14, SEn 15, or SEn 16. You are now in the setup menu.
6. Press the "SQ" key to toggle between KPH and MPH. When KPH mode is active, the letter M (presumably Metric) will be displayed on the top right of the screen.
7. Power off the unit. Your settings have been saved.
