Try switching the cable. It's a standard ethernet cable and it might have a communication issue with one of the pins. When you are switching back and forth it might be leaving the CPU in a mode that it doesn't require the problem pin. If that still doesn't work you are probably going to have to contact your AL distributor for a replacement. When I purchased my BT module, it was defective causing random disconnects. After Tom replaced mine everything has been solid.
