Fine , one step further : after i Jtk , would i see the led flashing when the cop keep shooting ?
I guess no because the Alp turns to parking mode ...though i would like to be so .
Mirage would you verify ?
Yes you continue to see the led flash if you are targeted even after it goes into detection only mode.
I think when you JTK it goes to detect-only mode to continue alerting until the LEO stops shooting, then it flips to parking mode afterward until it recycles to jam mode.
If I have before my trip I'm make a video and post it.
Sent from Miragetools.net
Went out last night and noticed that the flashing LED was very noticable while driving (i.e. afraid of attracting unwanted attention). This morning I uploaded new settings (PRO mode) to my USB drive and uploaded to the ALP. Tested with my LI keyfob tester...works BEAUTIFULLY!
becarefull with this and this goes with any AL jammer but while its in one minute warm up ...if you are tagged with laser it actually delays the warm up period ...for example im sitting at traffick lights and there is a poliscan ahead ...my system will either restart of I flick the switch ...while im still waiting for the lights to turn green I have re armed my AL but if these lights do not change and im still getting hit with lidar my AL will not start up until the threat has gone some times been over 3 minutes ....for member that own lidar and AL give it ago
I have tested this with my PL2 ...I start up the AL G8/G9/ALP if I was to constantly tag with laser while in warm up I will be waiting for ever even held the trigger for 2 minutes +.... not until there is no threat the system will arm up
also I have had laser based cruise control set off my rear ALps ...the bloody thing wouldn't arm its self until the car behind had gone
this also goes the same way on constant ...if there is any lidar present while turning on the key it will not start up
