X2. Or add a 2nd jack to the bluetooth module so you can plug the control module into that, and have it so either can work, with or without a BT connection or the app running.
if there is no connection the led will glow red when you start the car. Then you need to hit the switch and the on button on your control or start the bt on the phone. I find it easier to use the control on a short trip.
All sold out :( . I have one but would like another...works perfect
pm'd you
These switched are being sold on Amazon as well. This one is Prime eligible too:
MT-VIKI 2 Ports Network Switch Splitter Selector Hub 2-In 1-Out or 1-In 2-Out 100M MT-RJ45-2M
https://www.amazon.com/dp/B00DRG1SLO
I just ordered a few on eBay without even thinking to check Amazon, thanks for posting that up. Ordering another now since I am impatient. :thumbs2:
Those who are using this: is it a mechanical push button like the old school RCA switches? It would be cool if the switch could be triggered by an external switch mounted somewhere accessible.
Quick question, but has anyone tried using a power over ethernet switch? Are we sure that the issue isn't that these devices just require power over the ethernet cord? Anyways, I'm emailing them right now to ask.
You need a dumb switch that is switching from one port to the next. This is not a Ethernet connection and you will damage your ALP if you connect to an Ethernet switch or hub. It has to be a dumb switch that manually switches from one port to the next. The only one that will work is listed in the first post.
