Thanks dude!
This is true and confimed by Hwybear, an OPP officer who once stated on a different forum:
"One ticket for each device. It would actually then only be 3 demerit points. When tickets with points are wrote at the SAME DATE and SAME TIME the infraction with the highest points is used, no demerit points are assessed for the second or third offence."
Yes Alberta only uses 34.7 and 35.5 for Ka band. Since you live in Edmonton as long as you stay in the city limits you could run only 34.7 on the redline as EPS only uses that (including photo radar). If you plan on going outside the city limits make sure you turn on k band and 35.5 Ka band
Update: I have been running bands 2-9 on just while I get a feel for the local guns and whether or not they are out of tune. Well I can confirm after two encounters that 33.752 is in use by AB Sheriff's and possibly RCMP. I had one kit here in St. Albert that I couldn't find the source of (but it is only RCMP here) and one IO hit from a Sheriff's car today on 33.752 in a speed trap. So band 2 needs to be on in AB!
Here's a video from a Western Canada LEO (AvsBest) who was quite active on RD.net -
Sure looks like the Northern Rocky Mountains is the background:
http://www.youtube.com/watch?v=C35dWgWWPNo
Almost 100% sure St Albert doesn't use 33.7. You likely detected a cobra.
