Thank you. I'm asking because I live in banned area and would like to learn more.
I thought in the US
IL and some other states banned it?
Hi: If somebody can help me. Since I updated my ALP to version 5.3.1 radar (M3) never worked again. I waited for a while after I read in the forum that other people were having the same issue. Then they released the version 5.3.2 and...no change.
I did factory reset 3 times, new profile settings, checked all the connections and nothing. Now I received another FW update notification for version 5.3.3 and still the same. The radar is dead, it doesn't notify anything in the control unit or the application. No k band at all, no KA even in the wide setting. PDC & LDI are working fine.
I attached a couple of screen captures just in case for reference. Please note that in the statistics the control set says v 7.1 but in the app says v 7.3.
For any help or advice that somebody can give me, thanks in advance.
Attachment 5658Attachment 5659
Since getting latest firmware update my Multaradar CD alerts don't have audio half the time. LED goes red, phone goes crazy, no audio. The locations are not suppressed and the volume isn't muted, same locations alert sometimes and not others. Bel StiR
donnt run radar or hi-fi and no dragons here in OZ, so do i need to upgrade to the latest ?
reference to the latest 5..4.1 dont think Tom has posted it ?
update all done first time i tried setting every thing by using mi phone, great,even config :thumbs2:
As listed on the alpupdate website;
Quote:
5.4.1./7.4.
1. New option to Dark mode: Auto. When used will automatically change your LED dim
level according to time of day. ALP GPS antenna is required for time keeping.
2. The Define RADAR SPEED Limit option in the Online configurator has now been extended. You can now set speed limits for all of the bands together or you can set the speed limit for X and K bands.
3. Bug‐fixes.
i thought they were all listed on here at the start last one ( Control Box firmware update 5.3.2/7.3 (12.04.2017)
Whatever the changes I'm getting double the range on Gatso fixed cams.
gatso laser?
ok thought u ran with Stinger rd and laser
27.11.2018 Control Box firmware update
Release 5.5.1/8.1.
1. New Lidar support added and performance improved for several Lidars.
2. NetRadar antenna communication improved; random radar disconnect errors should happen less often. Make sure to update both the ALP and the radar antenna with the latest firmware.
3. Bug fixes and stability improvements, among which are:
- Improvements in activation of new settings when switching between profiles;
- switching between Profiles is now smoother;
- Force PDC, once Activated now remains active only in the current Profile;
- Automatic sensor check fail error F2/R2, caused by Laser Cruise Control interference during system powering - bug cleared.
- Audio alert loss in ProMode, bug fixed.
I am having trouble updating my firmware, it keeps saying checking captcha.
Hi :) New to this forum.
Just mountet AL Priority System on my motorcycle here in Norway. One front sensor. All looks well.. Only thing that I think is strange is when i Check System info on my phone (have the bluetooth module) It says: Region North America ? I did chose Europe when i initialy made my setup files online.. Anything I shuld worry about ?
Regards Per
Did you buy a North American ALP then its fixed to North American. You can not change that.
Sent from my SM-N960U using Tapatalk
OK.. well soo then it will not jam lasers here in Norway ? :( I spesific told Al Priority USA (Netelectronics?) that i was located in Norway.. Europe ...
Hi
Tnx for answer.. Not sure what the Norwegian guns are.. But got a New Control unit and its for Europa.. so all ok here now :) have one N.America Control unit now for sale
I still can’t update my ALP on my iPhone, it won’t get off the checking captcha notation.
Is this thread no longer being updated? Last post from 2019? The first post, firmware update versions stop at 04/12/17 - New Release to version 5.3.2. What update are we on? Here is what my system is showing. When I try and update the system checks and tells me I'm current, but I'm concerned I may have an older CPU that must be updated to get the latest versions? I read there would be a reduced-cost option for those forced to do so. Where is the info on that? Sorry if I seem lost, but I have been perusing the forums for an hour and can't find this info
Nothing???????
