The update site will not go away but many features that were once only set using setup files from the update site will be able to be done through the controller and through ALP Connect.
Here is a sound sample scrolling the menu's..
https://www.youtube.com/watch?v=Mawv...ature=youtu.be
Thanks for clarifying the intention to make updates available via ALP connect, I'm sick of hearing the whiners elsewhere complaining that AL should do this, it was stated long ago that this was in the works. Interw3bs comprehension is severely lacking these days. ALP is barely a year and half old and some people are asking for more than Blinder or LI ever delivered in their entire life cycle ffs.
I see you got that new TSS out of the box BRD :D
Sounds are clear and concise. Can't wait to get this installed. Tom, will 3M Molding tape be strong enough to hold the speaker flush against something like under the steering column, or would you recommend screwing the speaker in with the bracket if mounted that way. Just curious.
Tom, no need to rush my order, I can wait till you get caught up. No rush !!
