Right, I've got both on the recommended manual switch, so I might use the control set in the future. If the only useful changes are some volume adjustments and K band tones... I can do without it.
just agreeing with what u said and the k band warning, dont know if mine is different, but as i said it just voice announce once only, but the warning led light stays on until k threat is passed
Oh ok..
I Don't use the BT module only the control set as default.
Sent from my GT-I9305T using Tapatalk
When you use ALP Connect reported Control Set version is actually ALP Connect version (1.4) and hardware version is 4 (that means that you use ALP Connect).
If you want to check your control set version you have to use Control Set. ALP can't poll Control Set for firmware version if it's not connected to it!
