Issue with new ALP Setup - Please Help
Hi,
I had a Quad ALP setup installed by RadarRob in early October. The initial install went pretty smooth along with the testing. The BT app was working fine with my Samsung Note 4 as well.
I normally only use my car on the weekends, so the next weekend I start my car and the BT is no longer working. I can see that it is connecting fine because the led on the BT unit is flashing, but the application is saying otherwise. I keep getting an error returned to me in the app: "Please update the firmware to 4.5.1 or above."
I tried reinstalling the setup file after restoring to factory settings.
1. USB is a brand new working 16gb Sandisk 2.0 (Also tried a brand new working 64gb PNY 2.0 stick).
2. Formatted to FAT32.
3. Empty besides the setup.alp file (also tried just performing a firmware upgrade as well).
4. Tried recreating new setup files from alpupdate site multiple times.
5. Turn car off, unplug bt unit, connect standard controller harness, plug in usb, turn car on.
6. ALP boots up normally to green flashing lights, which then turn blue after a minute.
This happens every time I try to update. I've tried it many many times now and I can't get the unit to update at all. I even bought an IPod Touch to test the BT, since I heard the IOS app is a bit more stable. Nothing. The unit works with the regular controller I THINK (Have yet to get hit by laser, but the parking detection is working). I've also done a sensor test and everything rings up fine.
Forgot to mention I tried registering the control unit and heads, since I saw that was an issue for one person when trying to update just the firmware.*
Any ideas? Thanks in advance!
