ALP head placement suggestions?
I had my LI 8.9 dual setup tested a couple of weeks back and pretty much failed against the DET guns and some of the others as well. I have purchased a dual ALP setup that I want to replace the LI with. My plan is to spray the front grille which is a "glossy black" with plastidip to make it "matte black" this is more of a personal preference also. That should help with the center mass. We don't have front plates in PA so im ok there. Also the inside of my headlights are already a flat black from the LS430 retrofit. I want to avoid cutting the grille as much as possible unless I absolutely need to. What is the best placement for the ALP heads in my setup? Would the positions in Red further to the right of the current LI heads offer better protection for the massive headlights that my car has?
Attachment 4815
