I just purchased the system and have it set up on my bench so I can see all the pieces I need to deal with. This will be replacing a Laser Interceptor Gen8 I have installed in my BMW X6M. From what I've read the control module can be mounted in the engine bay (some place where it will not get wet,etc) if that is true this may be easier than the LI to install.
So far only disappointment has been that if you use the Bluetooth module and turn off the phone (or it dies, or battery runs out,etc) then the system will revert to unprotected (PA) mode.
So for now I will use hard wired. I have other questions (do I need two or three sensors for the front) but will try searching the forum.
Hope this meets the introduction requirement.
Dmlgc
