2 Q's re: sharing a speaker, extending HiFi cable length
Greetings! I'd intro'd myself in the appropriate forum, but from my sig you'll see I was previously heavily into CM use. I've been out of the game since changing cars (and moving to VA!) but am ready to get back into it. I still have my STi-R Plus so am planning on installing that into the Jeep, then adding an AL Priority dual. Two quick questions I couldn't find a good answer on:
1) Is it possible to use the STi's speaker for BOTH the ALP HiFi and the Bel? I assume electronically it can be done via some 1/8" plug wickering. Has anyone tried it or know whether or not this will work/is advisable?
2) In the Jeep the fuse box is in the engine bay. There is a switched 12v line available inside the cabin but I'm thinking about maybe installing everything next to the fuse box then just running a cable for the control set into the cabin. Is it possible to extend the length of the cord with a coupler? It looks like the connectors are standard RJ11 plugs. I did the crimp and extension act with the LI's before so can handle some cutting and crimping/soldering if necessary. Maybe the easier question is how long is the stock cable?
Thanks! Sorry my second post is a question. I'll try to provide some assistance and a DIY as I do the install. There aren't many DIY's on late model Jeep GC's.
