Hi Guys,
Does anyone know when the GPS units are going to be available for our ALPs:peach:
Hi Guys,
Have you give Tim a ring at DGC, he should be able to give you an time frame.
Why would you want GPS with the ALP ? just asking
Because you can set the speed in GPS and when being targeted you can have the ALP automatically kill when you get to the designated speed. It will also not Jam if traveling under the set speed limit. If you already have the radar package its only a $39.95 option but if you dont have the RG Module which is used in the radar integration it would be costly to add both. We have the GPS antenna's in stock but have not put them online for sale yet because AntiLaser did not have them available yet.
That's a great idea. Will that just be a firmware update?
Is that available for me with a redline or passport Max?
No, If you do not have the radar package you would need the RG Module to be able to connect the GPS antenna.
http://www.alpriorityusa.com/AL-Priority-RG-Module.html
No, as or Friday still not in yet and no real indication as to when:frown:
