Can I reload the .bin, .ucset and setup File
If I wanted to, can I just load the .bin, .ucset and alp setup file with the USB drive, and override what is on the CPU right now? Just curious as I'm not 100% sure I have the most current firmware. I tried saving the Stats to a different USB drive following Mirage's note from Nov and it did not work. I don't know what version I have. With the most recent firmware, it's my understanding that I could use Dim mode, but when I tried activating that through the controller, it only lets me do normal or dark mode, no Dim mode. Any help is appreciated of course. I know I can check the firmware version through the controller, but I just re-downloaded all 3 files to the USB and was going to load it later tonight or tomorrow morning. I have the unit in Privacy mode right now, so I would need to remove that USB stick to get it into regular mode, correct?
Thanks.
