ALP Statistics File (Udated)
You can now initiate a statistics write to the USB port through the ALP Connect App by pressing the settings tab and then hitting Save to USB. The original Control Module method is still available if you are not using the ALP Connect Bluetooth app. You can also memorize the position of your sensors to using the new Reset Defaults option in ALP Connect.
They added sensors connected to the statistics file to help when troubleshooting installations:
Device information
| Serial number |
XXXXXXX |
| Firmware version |
4.3.4 |
| Region |
North America |
| Power Cycles |
219 |
| Control Set FW version |
0.1 |
| Control Set HW version |
224 |
Connected sensors
| Connected sensors when manually memorized |
Front1 |
| Connected sensor (actual) |
Front1 |
Settings
| Audio Volume |
3 |
| Parking detection range |
3 |
| Silent Power-up |
Disabled |
| Dark Mode |
n/a |
| Parking enabled sensors |
Front1, Front2, Front3, Rear1, Rear2 |
| GPS Antenna |
None |
| PDC Speed Limit |
NONE |
| Working mode |
Parking and Laser Interference Defense |
| Pro mode |
Disabled |
| LID Speed Limit |
NONE |
| Radar Antenna Model |
STIR+ |
| Radar Settings |
X, K, Ka |
| LID Time |
Unlimited – Test purposes |
Specific LID settings
Vitronic Poliscan
Speed scanner |
Enabled |
Unicam Camera
Section speed control |
All sensors ON |
NJL SCS
Speed-laser |
Enabled |
Riegl
Speed-laser |
Enabled |
Trafic Observer
Speed scanner |
Enabled |
Stalker
Speed-laser |
Maximum Power |
Alerts by Source Speed-laser
| Marksman and UltraLyte |
146 |
| Atlanta SpeedLaser Stealth |
8 |
| Kustom ProLaser 1 |
10 |
| Kustom ProLaser & ProLite |
45 |
| Redspeed SpeedGuard |
0 |
| Riegl |
0 |
| Stalker |
170 |
| LTI Truspeed |
76 |
| Unipar - SL700 |
0 |
| NJL SCS 101 & 102 |
0 |
| Jenoptik – Laveg |
0 |
| Leivtec XV 2 |
0 |
| Laser Ally |
378 |
Error Sensitive Lasers
| Jenoptik LaserPatrol |
0 |
| Jenoptik TraffiPatrol XR |
0 |
| ProLaser 2 & Atlanta SpeedLaser |
15 |
Speed Section Control
| Camea - IR Camera |
0 |
Speed Scanner
| Traffic Observer |
0 |
| Vitronic Poliscan |
13 |
Radar
| K-band |
186 |
| Ka-band |
74 |
| X-band |
1 |
| POP |
23 |
| MultaRadar CD |
0 |
