Configuration Help: LED Behaivior Switching Between HiFi & Alp Connect
FYI: My CPU is HW2, I'm running the latest FW, Voice Pack, and Quint with a TX front & Rear.
Before adding the rear RX & TX, in ALP Connect (ALPC) mode I had the external LED on the lowest setting, and when switching to HiFi I had the External LED off with just the control set LED on.
Now these external LED settings seem to follow the last loaded config.
I use modify in ALPC to setup my config with the external LED on lowest setting and run it. Good.
Then I shut the car off, open the door to make sure the power is off.
Kill the ALPC.
I load my USB config setup with the external LED off and its fine.
Now I switch to the ALPC mode and the External LED is off. Some one tell me if what I had before is a fluke or ......
