Results 1 to 7 of 7
    Fort Lauderdale, FL
    Is There A Way To Test TX Head
    I have a laser tester for my normal ALP laser heads but I was wondering if there is a way to test a TX head to see if it is working correctly.
    Greg Rice
    IBA 382
    www.gregrice.com
    Quote Originally Posted by gregrice56 View Post
    No, you won't see a TX Sensor fire. Pull a stats report and if you see it listed you are good to go.
    modsl55amg (09-02-2017)
    Fort Lauderdale, FL
    Ok, thanks.
    Greg Rice
    IBA 382
    www.gregrice.com
    Fort Lauderdale, FL
    Does this look correct for the TX sensor?
    Greg Rice
    IBA 382
    www.gregrice.com
    Did you only install TX in front?
    Fort Lauderdale, FL
    Yes, I have only 1 TX sensor on the front along with 2 regular ALP laser heads. This is a motorcycle.
    Greg Rice
    IBA 382
    www.gregrice.com
  8. #7
    Member angrypenguin's Avatar
    Oct 2016
    It looks fine.
