Results 1 to 4 of 4
    Member machtschnell's Avatar
    Jun 2015
    Issues installing new TX head
    So I had an F2 and F3 sensor fail. I swapped cpu's in my vehicles and updated all firmware. Then I was only getting automatic senor check fail senor F2. The other vehicle runs fine. I had been debating on updating to a TX head for the front. (quint systems on both vehicles) so I used this as the opportunity to make the swap. I first tried plugging the TX head into the existing extension line to the cpu. getting same error code. so I run the new extension wire from the TX head to the CPU and getting the same error still. Any ideas on what to check next?
    Hard mounted 9500ix, Escort Live, ALP Quad w/ BT, Waze
    Jun 2015
    I should note also I tried using a different hifi connection and still the same issue.
  3. #3
    Quote Originally Posted by machtschnell View Post
    Did you run a factory reset to memorize the hardware change. Anytime you change any hardware you need to run a factory reset or you will get a sensor check fail because your. Hardware configuration changed. TX Sensors also can only be used on #2 ports so in the front it needs to be plugged into the F2 port.
    Sent from my SM-N960U using Tapatalk
  4. #4
    Jun 2015
    Feeling really stupid right now...itís set and working thanks.
