Update just fixed a few very minor bugs which is why we did not mention it. Nothing important or we would have made an announcement.
Will there ever be an app for an Android type phone (for those who do not have an iPhone/iPod)? Not sure if this was previously discussed.
Ever since I installed the latest App update, I am having issues with sound from my iPhone.
What happens is my iPhone is connected to my car system via the USB connection. When I turn on the App it firstly stops the audio as if paused. I then have to physically hit the pause button which actually pauses the audio system ie pause actually comes up on the display, I hit pause again, and the music starts. However, the volume of the music is now around half of its normal volume for the position of the volume dial.
Is anyone else having a similar issue since the update? I had no problems before the update.
Thanks guys:happy:
this may help on the menu alp app change the audio output from default to speaker and try that, that fixed a prob with my iphone sound, but was a bit different to ur fault just give it a try
Have done that no difference with either of the two last options. All I can think its a bug in the latest upgrade
May be wait for USA to wake up
Have you tried switching the Audio from DUCK to MIX? Duck means exactly that, it lowers audio volume of a background player so ALPC alerts are heard as louder. MIX should keep the volume as is. Try switching to MIX and then reset the app, phone and your car stereo.
Thanks will give it a try:kiwi-fruit:
Tried it and works fine. However, two things.
1. Why does it mute/pause the media player every time it turns on. I have to hit pause to pause the player, even though it has been paused by the App and then hit the pause button again which physically unpasues the unit and it plays from there.
2. Would not Duck be better programmed to ONLY lower the volume of the media player upon getting an alert? It seems silly to lower the volume of your audio when there is no alert, so mix is a true mix and Duck is a true Duck when you get an alert. hope that makes sense:applause:
