You can switch Profiles in BT
Ok great, can you link me to infonthat describes jow to use more than one profile in BT when no hifi is used. Does a usb stick need to be plugged in. Thank you
As Tom says, just check the 'use profiles' on the alpupdate configure page ;
Attachment 5600
Setup your three profiles as you want on the 3 pages (profile A, B & C), download the config.alp file from the website, put on USB stick, plug into the ALP, and you will be able to switch between A,B & C on the ALPConnect app. You can then remove the USB stick
oh you can do that without Hifi ! Awesome.
i was reading this and thought he said thats not possible with no hifi
http://www.vortexradar.com/2016/01/a...aser-priority/
ok great thanks !
So I have the iPhone 7 Plus. I have the ALPConnect app installed. Is their a way to have the app go into landscape mode? Cause as far as I can tell the app is only in Portrait mode. While it's not the worse of deals, I usually use it in the background with my GPS navigation on the screen in landscape mode so if I have to switch back to the app I have to rotate my phone to portrait to be able to see what I am doing. Is it possible to update it so that landscape is supported or am I missing something?
