What is the maximum recommended size/capacity (GB) for use with the ALP system?
Since I had ALP systems installed in both of my cars in 2015/2016, I have successfully used Verbatim 8GB Pinstripe Flash Drives, with no problems whatsoever caused by the Verbatim 8GB Flash Drives.
I recall reading, years ago, that flash drives with a low capacity should be used, and that some people have had problems using a flash drive with high capacities.
Question: Would it be OK for me to use Verbatim 16GB flash drives to load new updates into my ALP systems? Or, does anyone know if the 16GB flash drives are too large in their capacity and would cause possible problems?
Thanks in advance for your advice/experience/recommendations.
