ALP Jammers do not operate the same as old jammers. All you need is 3 sensors and adding more will decrease and not improve performance. We have large trucks running ALP'S with a Triple with JTG testing.
I am only concerned with front protection on this 2017 SS camaro. So a 3 head install is better than 5 head on the front? Next question is what site is the best to order this from? There are several sites, and I do not want to get burned. I will purchase 2 units. Thanks.
For best protection 3 Transponders will give you excellent protection against all the current & known Lidars used by Law Enforcement.
However, I am not discouraging you from buying 2 separate AL-P systems to give full protection at this time for FRONT & REAR, but feel compelled to let you know also that there has been some hints that AntiLaser may offer a modified "Priority" update to the current generation that will allow for MORE than 3 Transponders each side. - ( Speculation recently was that it might be available in 1st Qtr of 2017. )
p.s. - Re: Post #61 above..."BestRadarDetectors" is your source to buy from.... 'click' on the hot link provided in the signature area at the bottom of Tom's post.
Is there a licence plate mount setup for the ALP sensors? (using the license plate top bolt holes?) I was looking on line and cannot find anything that would universally support two sensors on either side of the plate at the top.
